lowering a 64?
lowering a 64?
I have a 64 F100 sb and I've been wondering how to lower it. I read someone else had asked about a 64 and was told to go to www.truckn-store.com, so I went there and they have lowering kits for 65-81 fords. I was wondering if the 64 was the same as 65? Or what is another way to lower it?
Thanks,
psyko64
Thanks,
psyko64
If it really is a '64, it'll have a straight solid axle, instead of the twin I-Beam of '65 and up. The later kit won't fit. Check the '48-'60 forum; they've got a lot more stuff on it, and the same principles apply. Do a search on lowering. Also, they've got a sticky on various options for replacing your front end with a later IFS, which will do a lot more for your truck than simply lowering (Better ride, handling, power steering, power disc brakes, later model motor mounts, etc.) Many like to keep the original hardware, tho'.
urquidezp
19
10-02-2010 09:24 PM
