ABS problems
AFter a rebuild of the front end the ABS system failed the yellow ABS lamp is lit all the time and the ABS is not functional. The fuses are ok and the brake fluid ok. The sensors on the front wheels were removed during the rebuild but not disconnected. Anyone has any ideas what to check except electrical connectors to pump and solenoid?
The sensors looks robust but could they have been damaged anyway?
Could dirt around the teeth on the axle disturb the sensors?
Any other ideas?
1993 4x4 Explorer (not the early RABS)
JO/Sweden
