2.3 miliage help needed
Hey folks, Need some advice, I have a 92' Ext. Cab Ranger with a 2.3 5spd. My problem is I am only getting around 19 miles to the gallon, Recent tune-up, (last month). I think I drive decently, country roads and freeways, what kind of things do the moreknowledgablethanme suggest I look at?
Thanks in advance for the help
Ammo Troop
Ammo Troop
Run 5w30 oil, keep the tire pressures up, make sure the fuel system is clean, clean air filter, don't gear down in leu of using the brakes, only use the A/C when really needed, keep the use of the accelerator smooth(don't stab the gas).
Look into minor mods like exhaust, etc. @ MotorHaven.
Read up in the Ranger forum.
AL.
AL.
did the sparkplugs get replaced? if so what kind??
Ammo Troop
Ammo Troop
Yup, Replaced the plugs (motorcraft plat) and wires, ran Seafoam thru, cleaned IAC, MAS, freed the intake a little, running 5W30 Mobil 1 and still getting the same milage 17-19 MPG. Haven't had time to get the code read, seems there is no where around here (Ohio) that pulls codes for free anymore.
Any suggestions??
Thanks!
Any suggestions??
Thanks!
Engine Coolant Temperature. You might also check the ACT, too.. Air Charge Temperature. (temperature of the air coming into the intake. will add extra fuel if the ECM thinks it's cold outside...) They can also get coated with muck from the PCV valve & EGR that is inducted into the intake manifold, thus sending a false signal to the ECM. Unscrew it from the intake, and inspect it for gunk.
tom
tom
DannyInSoCal
S. California Chapter
13
02-14-2014 01:24 AM
