4.0L Aerostar OBD? Can I get codes?
I just replaced the ECT. The engine still misses. I thought I heard a snapping sound that might me a shorting spark. I taped a small mirror to the end of a magnetic pick-up tool and there it is. #5 is shorting around the center of the plug to the grounded outside of the plug.
What causes this and how do I fix the situation.
Dativer
Dativer
Originally Posted by dativer
... I taped a small mirror to the end of a magnetic pick-up tool and there it is. #5 is shorting around the center of the plug to the grounded outside of the plug.
Dativer
Dativer
I'm not sure I understand completely...is it arcing right through the boot? Try exchanging the suspect wire with another one and see if the problem follows the wire, or stays with the plug/cylinder.
And yes, a little dielelctric grease around the rim of the plug wire boots is adviseable.
What if I put dielectric grease on the contact? I may have used it on the contact of #5 wire also.
Would that increase the resistance enough to divert the spark around the plug?
What solvent would clean off the dielectric from the contact?
Dativer
Dativer
boilerbots
06-02-2019 12:09 AM
