steer gear box adj
Old Jul 31, 2004 | 01:03 AM
smithdblue's Avatar
smithdblue
steer gear box adj
Could someone tell me how to adjust the slack in my steering on my '88 f150,it's getting hard to keep it between the ditches.Thanks to all for replying,Danny
Old Jul 31, 2004 | 01:13 AM
kameronth's Avatar
kameronth
I have no idea but you might want to try the f-150 forum, not general conversation.
Old Jul 31, 2004 | 02:11 PM
mjb1962's Avatar
mjb1962
On the top of the box there is a set screw with a locking nut. The nut on mine is 5/8" Loosen the lock nut and hold it with the wrench while you adjust the screw. Clockwise rotation tightens the box, it tightens the sector teeth engagement to the nut internal of the box. Tighten 1/8 to 1/4 turn at a time and check it. Eventually you will feel the steering wheel not return to center as well so back it off a bit at this point.
Mark
Old Jul 31, 2004 | 02:13 PM
mjb1962's Avatar
mjb1962
Actually, before you do this make sure there is no play in the steering and suspension bushings. Only adjust the box if you know it is the component with the play in it.
Mark
Roger C
Feb 16, 2017 09:57 AM
ibewshooter
2015 - 2020 F150
Apr 22, 2016 07:46 AM
Juddpease
Jan 10, 2015 09:37 AM
351Cleveland C4
Dec 18, 2014 08:06 PM
Opossum
Mar 14, 2014 11:09 PM
