1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
constant 12 volt wire for 7 way connector
Old 07-26-2004, 06:33 PM
97_Ex's Avatar
97_Ex
97_Ex is offline
I know where the pre wired brake controller harness is in my 97 Ex but I was wondering if it was also pre wired for constant 12 volt for the interior lights and battery on my trailer
Old 07-26-2004, 07:28 PM
daigles's Avatar
daigles
daigles is offline
Yes, the 7 pin connector is wired for a constant 12v (15 amp?) connection; the pin out "should" be on the connector's cover. This is a switched connection, so it will only work with the ignition on. You should be able to test this with a multimeter.
Old 07-26-2004, 07:49 PM
97_Ex's Avatar
97_Ex
97_Ex is offline
mine came with a flat 4 and I changed it to a 7 way but the trailer I had did not need a constant 12 volts. The new one does but I figured if the Ex was wired already it would save me some time. The 2 wires at the rear of the truck that are in a grey connector include the brake wire form the front but the other does nothing. I figured it would be the 12 volt one I needed.... Please help!
Old 07-26-2004, 10:00 PM
daveplot's Avatar
daveplot
daveplot is offline
The constant power should be the center pin on the connector (30 amp). I use it on my truck to power a boat winch. If it's not prewired run a wire with an inline fuse direcly from the battery to the center pin.
Schuyles
02-20-2024 04:35 PM
Dieselman1987
2017+ Super Duty
16
03-24-2017 07:03 AM
hasteranger
05-24-2016 02:21 AM
Mangelsen22
2004 - 2008 F150
10-02-2015 01:04 AM
jimexpedition99
06-12-2006 07:01 PM
Quick Reply: constant 12 volt wire for 7 way connector
