This is great. Im from Nebraska hopefully well get one started soon. Lots of Ford fans out here. Ill be checking on down here to see whats going on. Congrats is in order here. Good Luck.
i did the work for hummer thing out of oxford, lasted 2 years there and then got home, the decker thing is ok, but can be a headache on other ends. but you can get on local with them, get home on the weekends. look for a union job with usf they pay real good. good luck
I talked to Gray and Zephr gray only wanted a years worth of experence and Zephr wanted 2. I got acceppted with Crete Carrier Corporation out of Lincoln Nebraska. A dedicated route out of Cedar Rapids is pretty nice to start out with. And I like the pay and how they only 17% drop out rate for newbs. Also Everyone I talked to that worked with them said that they had no complaints. depending on when my trainer shows up in the area I leave ethier tuesday night or thursday night. Thanks for everybodies support!!!!!!
Until you get more established over there, you're certainly welcome to come join us too. (even after!!) As the leaders of the High plains well know, the hardest part of being so big is that it is tough to get everyone together. I want to try to move the meetings around to different areas to try to get everyone a chance to have it in their back yard, so to speak. Not everyone will make it, so I thought this could help everyone be involved over time, just not necessarily the same meetings, unfortunately. You could try rounding up the guys to make more participation, and form your own chapter, as there are plenty available to make your chapter, or at least get them together under the Plains to get your base started like we did. Click members, then search, then advanced search. Put in your states abbreviation, put 10 post count minimum or you'll be swamped, and there are 3 pages of candidates.
