I just did a clutch on a 1996 F-150 4x4. Cltuch works just fine now, the problem is that I can not get the truck out of gear or switch gears. It seems to be stuck in 2nd. Anyone have an idea of what could be wrong? The transmission itself was never taken apart.
The clutch is not disenaging for some reason? Maybe the inpiut shaft is bound up some how as well? Can you start the truck and not have it move? Can you spin the drive shaft by hand?
Are you sure you got all the linkage hooked back up correctly and adjusted correctly and that the clutch fluid is full(assuming it's an hydraulic clutch), maybe the clutch is not disengaging all the way and that's why the tranny won't shift.
