Did a 460 come in a highboy
I believe Ford started putting the 460's in some of the 80's 4x4's but they were never used in any of the 70's 4wd trucks, just 2wd. The other thing to remember when you see 4x4's advertised in the paper is half the people out there don't have a clue what they're talking about when it comes to engines. All they know is they put gas in it and drive. If you're going to buy a truck take some time to get familiar with the characteristics of the 460 (valve cover bolt pattern, verticle water neck, etc) so you'll know what to look for when you check them out. Around here I've seen people push 351's and 390's as 460's. And they'll argue up and down with me when I tell them otherwise.
The following users liked this post:
Why they put a 460 in a 2wd back in the 70s and not in the 4 wheel drives is more than I kinow. A 400 was the biggest motor you could get in a 79.. I believe the former poster is right about the 460 back in 1983. A neighbor of mine had a 350 4x4 withy the 400 in it. 4spd. He tractor pulled with a tractor all over and pulled his trailor with this truck he wish hed had a little more power. If it was me Id swap a 460 in there. youll have plenty of power and be able to pull anything. As for highboys the last year for them I believe was 1977. A friend of mine has a 77 its a highboy. But i believe thats the last year.
Originally Posted by LxMan1
I believe they didn't put them into the 4x4's to keep from fixing a bunch of broken 4x4 parts under warranty.
I am not sure what inspection you have or what IM is, but the 460 was offered from 73-79 in the 2WD trucks. So you should be able to get by with a swap in a 4x4 by being able to show it was available. Would whoever inspects it even know the difference between a big block and an FE or 400? I would think if it is stock in appearance you should be fine.
I have one
I have a 1973 f250 single cab long box highboy 4x4 with a 460 in it don't know if it's original though.
Think about it. They didn't offer the two big engines, 390 & 460, in 4wd trucks. The later front disc brake caliper brackets are the same as those on big cars, yet Ford put a weak small piston caliper on 1/2 ton 4wd trucks, while putting a large piston caliper on cars. Everyone I knew that had a 2wd Ford truck, had AC, but we had to wait for months when we special ordered our 4wd trucks with AC. On one of them, we had to settle for dealer installed aftermarket AC.
My how times have changed.
460 WAS not available (FROM THE FACTORY) with 4WD or a Manual Trans until 1983, then only in F250/350's
No 460's available in F100's after 1976, F150's after 1979 (CA:1978). And that is all 2wd only
No 460's available in 1980/82 F250/350's, E250/350's only.
1983/97 F250/350 460's have a hydraulic clutch.
Highboy 101 https://www.ford-trucks.com/forums/9...mpilation.html
Lance-25_
05-11-2009 08:21 PM
f250rangerexplorer
12-05-2004 11:02 PM
