Kwikkordead??
Thanks
Steve
I got my instructions by reading TexasTowncar's experience and following what they did. An associate of his posted some very excellent pictures that will tell the story far better than I could describe. Here is the link: http://community.webshots.com/album/32614313yLKyrS
My variation to his was I reused my pickup screen. I made the 3/8 pickup tube long enough to reach down past the little side valve that is built into it and disable it. You'll see what I mean when you get the pickup out. It's a little orange flapper thing that looks like it will let air in through the side. Block that with the 3/8 pipe.
I used 7mm metric hose and it was a little tight. But I wanted a good air seal. I would recommend it if you can get it. It worked everywhere. Otherwise the fuel outlet at the tank is 3/8. But I would get some 5/16 too as I "think" the fuel pump inlet is a touch smaller. What you want to avoid at all costs is to have the fuel line be larger than the steel line and then try and seal it up with clamps. If it doesn't push on with firm pressure the hose is too loose and will let air in eventually. Recommend at least two or three hose clamps at each flange set 180 degrees from each other for the best clamping job. One head of the clamp on the top of the line and the other head of the clamp on the bottom of the line with the clamps right next to each other. I bought the steel lines needed at my local NAPA store. They have and assortment of brake lines. You'll need both 3/8 and 5/16 steel lines. Study the picture of the converted fuel pickup. You'll see the compression fittings you'll need to join it all together. You can get a 3/8 double ended fitting all in one piece, but the 5/16 fitting will have to be assembled from different types of fittings as there doesn't seem to be any available in the style needed. You'll need a tubing bender, or in a pinch a piece of 1" pipe to provide a curved surface to bend the fuel return away from the fuel gauge sender. A tubing cutter, and some basic tools are all that's needed except for removing the factory flex line from the frame mounted steel line. It's a stainless steel crimp setup that requires a die grinder with a cutter wheel to seperate. If you don't have that just cut the end off with your tubing cutter and install the hose there. Use at least two clamps, four would be good.
Anyway I need to get off to work now. Recommend registering at www.texastowncar.com and reading about what they did. That's where I got all this.
Good luck and God bless your efforts.
I sent you a PM.
