torque spec. on shakles?
Best I can do is give you the spec for a 95 - I don't know if it will help or not but I do not have any other informaiton.
Shackle bolts and spring bolts (both ends of the spring have the same torque spec) show 120 - 150 lb ft for a monobeam front suspension in a 4x4 for the F250 and F350. U bolts are 85 - 120 lb ft.
These are for the 1995 trucks, spec may have changed in 9 years.
Sorry it is all I have.
Dave / Believer45
Dave / Believer45
Originally Posted by 350z
Anyone know the torque specs on the front shakles, on the rear of the front leaf springs. (04 f350 srw) thanks in advance ,craig.
The second number is for foot/pounds...
Torque Specifications (Front Suspension)
Description Nm lb-ft
Front spring-to-axle U-bolts 133 99
Front spring-to-spring hanger nut 275 203
Front spring-to-shackle nut 250 185
Spring hanger-to-frame bolts 103 76
Spring shackle-to-frame nut 250 185
Stabilizer bar-to-front spring spacer bolts (LH side only) 55 41
Stabilizer bar-to-axle assembly bracket bolts (RH side only) 55 41
Stabilizer bar-to-link nut 109 80
Stabilizer bar link-to-bracket nut 109 80
Front shock-to-upper shock bracket nut 103 76
Front shock-to-front spring spacer nut 103 76
Jounce bumper-to-frame bolts 40 30
Shock absorber upper mounting bracket-to-frame bolts 103 76
Track bar-to-upper mounting bracket nut 550 406
Track bar-to-lower mounting bracket nut 550 406
Shackle bracket assembly-to-frame bolts 90 66
Stabilizer bar bracket-to-frame bolts 47 35
Front driveshaft-to-pinion flange bolts 102 76
Front hub and bearing-to-knuckle nuts 74 55
Tie-rod end-to-front knuckle nut 70 52
Lower ball joint nut 204 150
Upper ball joint nut 94 69
Torque Specifications (Rear Suspension)
Super Duty F-250, F-350 Wide Frame
Leaf spring-to-axle U-bolt nut 250 185
Leaf spring-to-front spring hanger bracket nut and bolt 250 185
Leaf spring-to-rear shackle nut and bolt 250 185
Rear shackle-to-frame mounted bracket nut and bolt 250 185
Shock absorber-to-frame mounted bracket nut 62 46
Shock absorber-to-axle bracket nut and bolt 62 46
Shock absorber bracket-to-axle U-bolt and nut (Ford axle) 55 41
Stabilizer bar retainer bracket-to-axle bolt (Dana axle) 40 30
Stabilizer bar retainer bracket-to-axle U-bolt and nut (Ford axle) 47 35
Stabilizer bar link-to-frame nut 70 52
Stabilizer bar link-to-stabilizer bar nut 70 52
jabberwoki
10-27-2015 10:14 PM
vandorin123
172
10-12-2015 12:37 AM
