Sponsored by: Kumho
alignment question
Old Jul 20, 2004 | 09:09 PM
FordPickMeUp's Avatar
FordPickMeUp
alignment question
when you take your tires and rims off your truck doesnt that mess your alignment up?..i was told everytime i take my tires off my truck lets say i took the tire off the change a flat then i put it back on that will mess up my alignment wont it?..one guy tells me it will another says no..who is right?
Old Jul 20, 2004 | 10:34 PM
psdpower's Avatar
psdpower
No your alignment won't change just taking off a tire and putting it back on. If you drastically change tire size when you have them off it could effect your alignment. Aren't TTB trucks great!!!
Old Jul 20, 2004 | 11:37 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Even a change in tire size shouldn't affect the alignment, unless a lift kit was added to fit the larger tires.
Feel free to change your tires as often as you like and don't worry about the alignment getting off because if it .
Old Jul 21, 2004 | 07:20 PM
FordPickMeUp
hmm ok thanks for the info guys i know i can always get a good answer here..later
Old Jul 24, 2004 | 12:53 AM
psdpower's Avatar
psdpower
Wider tires or wheels with more offset could effect camber, but SoCal is right you would probably have to lift it to make a big enough tire change. If you lifted it you would need an alignment anyway.
