Power Windows wiring diagram 1993 XLT
Old 05-24-2002, 10:01 PM
japetty's Avatar
japetty
japetty is offline
Pass+2 rear door switchs don't work. Some times Drivers door switch works sometimes not.
Old 05-24-2002, 10:57 PM
Dialtone's Avatar
Dialtone
Dialtone is offline
[updated:LAST EDITED ON 25-May-02 AT 00:02 AM (EST)]Diagram shows all power to window switches comes from interior fuse panel fuse 14, 30 amp. Power to all window switches EXCEPT drivers panel switches, pass thru the window lock switch before going to the individual window switches. I suspect you may have an open in the lock out switch, especially if you can control them from the drivers switch panel. Power from fuse goes into the driver switch panel on a LB/BK (light blue/ black?)wire and exits the lock out switch on a BR (brown?)wire, then runs to the 3 other window switches.
Since you mentioned that sometimes drivers swithes does not work also, see if the switches are mounted on some type of circuit board and if so, check the wiring path on it for a break caused by repeated flexing of the circuit board. Also check the point where the wiring harness connector joins it for a bad/broken/loose solder joint.
Hope this helps.
Dialtone
Old 05-25-2002, 09:49 AM
japetty's Avatar
japetty
japetty is offline
>switches.
>Hope this helps.
>Dialtone
Thanks for the help. I will check it out as soon as I can this week end.
Jim
Old 05-27-2002, 08:33 PM
japetty's Avatar
japetty
japetty is offline
Got all the problems taken care of by taking the switchs out taking them apart and burnishing all the contacts with the handy dandy burnishing tool I used when I worked for Pacific Bell. All works now and my son is real happy about the fact it did not cost him any money.
Old 05-28-2002, 02:41 PM
ckrichard's Avatar
ckrichard
ckrichard is offline
Post Power Windows wiring diagram 1993 XLT
A/Ox4
2009 - 2014 F150
12-02-2016 07:34 PM
Elmo154
11-17-2015 03:11 PM
moorebounce
11-06-2015 04:55 PM
projump
2004 - 2008 F150
07-18-2015 07:38 PM
jonboy88
20
06-12-2006 03:35 PM
Quick Reply: Power Windows wiring diagram 1993 XLT
