302 only running on 4 cylinders
Greetings,
I'm posting about a '68 302. It's in a boat but I'm told it's a truck engine, and I'm desperate for advice.
History:
Last year had the motor rebuilt by local engine builder.
Installed factory Ford aluminum four barrel intake and Holley 650
First two times on water, about 30 minutes each, ran good and smooth.
Third time on water, developed vibration, put it up for winter.
This year tried new harmonic balancer, no change.
Check plug wires and found that engine missing on every other cylinder, starting with number one cylinder.
Switch wires from adjacent cylinders, no difference.
Switched plugs from adjacent cylinders, no change.
Check for valve closure, valves closing.
Checked compression, has compression.
Checked spark at plug end of wires, has spark, orange.
Changed points to Unilite electronic,and high output coil, no change.
Double checked spark at end of wires, has spark, orange.
Changed spark plugs, last years plugs dark, but no buildup.
Still missing on every other cylinder.
Help
History:
Help
4 cylinders
i therefore clean the other and still no gas. I spray the faulty side and it works.
yet does not when I don’t inject it.
thoughts?
I would rebuild the carburetor; take it apart, use lots of carb cleaner to clan out all the passages. You can point the straw of the pressurized cleaner and put its tip against any of the ports and openings you find and spritz away. Watch for where the cleaner shoots out and make sure both sides do the same. Get a rebuild kit, which usually includes all the gaskets and seals, as you will be scraping the old ones off all the surfaces on the carb.
mnkeeking
05-07-2012 08:50 AM
hdwideglide94
10-04-2005 11:23 AM
lost_in_space
16
03-05-2005 05:03 PM
