You sure can. That is the exact parts I used to convert my F250 to 4wd. Some will tell you that you need the knuckles out. You only need the spindles out. Ted
Add to that. Ford drum setups have 5 bolt holes in the knuckles / spindles and disk setups have 6 holes so swapping from drum to disk setups require replacing knuckles and all. Can't have drum knuckles and disk spindles ect.
I just did the 8 lug conversion. Completely bolt-on and go.
