Does anyone have a recommended method for removing the dealers logo decal from the tailgate of my truck? I want to take it off, but I don't want to damage the paint.
what kind of logo is it? is it a sticker type or like on my truck its a plastic logo with a foam tape on the back. various methods have been used, hair drier, heat guns, adhesive remover. i prefer the heating method, just have to be careful and take your time is all.
You can probably just peel it off and use goof off to get the glue residue off. I peeled 8 feet of chrome rocker panel molding off so you should be able to get the emblem off with no problem.
Thanks fellas. Just to clarify, it's the sticker kind. I think the emblem would actually be easier to get off because you have something to grab hold of. Has anyone taken the sticker type off, if so, any tricks I should know about?
If its cool outside, use a hairdryer and your fingernail to start it. I also found that using turtle wax on the sticky residue left after peeling the sticker off removed it quite well.
I hate these stickers. Typically they last about an hour on any vehicle i've ever owned. Heat is helpful, but you don't really need a lot. Park the vehicle in a position that allows the sun to work on the sticker for a couple of hours. I've had good luck peeling them off with my fingernails. I've used WD-40 and a clean towel to pull off the adhesive residue, just be certain to wash off the paint with soap and water as soon as possible, as WD-40 is petroleum-based.
I have always used my fingernails with no problems, sometimes the stickes like to come off in small pieces if they are on too long. I did buy a vehicle once that was a dealer trade, and it looked like the dealer I bought it from used a razor blade to take off the original dealers stickers, I found nice scrape lines under the new sticker. Removal of the dealer sticker is one of the first things I do to a new vehicle.
I don't know about a new vehicle with nice new paint BUT on my old Aerostar van I wanted to remove some sticky residue and WD-40 worked great. Didn't take off the paint.
When I removed mine (rubber sticker type), I used my fingernail to pry open a corner, then I sprayed WD between the sticker and paint and SLOWLY peeled back, while spraying more WD(must of used a quarter of a can--But my paint is still good). To clean up, I used more WD and a old microfiber cloth. Washed the truck and waxed the area where the sticker was
