C-6 Tranny with a 2.75 Gear Ratio?
You have posted a list of ratios. What it means is the engine turns this many times for the tires one time. Since all non over/under drive trannys turn 1 to 1 with the engine, a 2.75 ratio for example the engine is turning 2 and 3/4s times per the tires one rotation.
As long as the engine can handle the power, the lower the numbers like 2.75 the wheel is turning faster at a lower engine speed. With 3.55 or 4.11 the engine is turning a lot faster to acheive the same tire speed.
The I6 in your truck needs to build more speed to make it's horsepower and the 2.75 ratio is not allowing that to happen. A 3.50 or 3.75 ratio will allow the engine more rpms and it will make it happier, and better gas milage.
hope this helps
John
hope this helps
John
You need to know the torque, not horsepower band for your engine. Usually, engines are most efficent near the torque peak. The 300ci six and the deisels tend to have peak torque at a lower rpm than the gas V-8's. Lets say that your engine torque peaks at 2000 rpm and you like to cruise at 65mph. Find the gearing, with your current tire size, that will give you that rpm/speed combination in high gear.
For example, my old Ranger 2.9 V-6 had the Mazda 5-speed OD, 3.45 gears and 14 inch tires. It all worked out to a 68mph speed at peak torque, and it got the full EPA estimated highway mpg at that speed. My current F-150 4x4/5.0/E4OD/3.55/29in tires gets way less than the EPA estimated 18mpg, more like 15 or less. I have to drive at 75mph to get the engine up into the torque band and at that speed the wind resistance eats up too much gas. At lower speeds, it labors and wont stay in OD, again eating up gas.
Jim
Jim
Jim
Jim
i thought the peak efficiency had to do w/the vacuum. i read somewhere that a vacuum guage can tell where your engine is operating most efficiently. most gassers creat their peak torque at 3-5k rpm's. try cruising at that range and look at the gas bill.
Originally Posted by Sgt Wonderful
But it seams to me that if an engine is turning faster it would use more GAS to make it turn faster, is that correct? If so how can it have better MPG, turning more RPM's
Hope that made sense, I've had a bit to drink and I'm a little incoherant.
Jim
Doc, No I dont really know how to make the change. If I got a rear-end (just the gears) from a ford Bronco, could I just take my gears out and replace them with the ones from the Bronco?
John
John
jamusfam
04-24-2014 06:20 PM
Old Rusty
02-03-2013 10:32 PM
I_Thnk_Ford
19
04-02-2006 02:02 PM
ole_blue
Offroad & 4x4
03-14-2002 06:09 PM
