I was looking at one of the archived articles https://www.ford-trucks.com/articles/axlechart.php concerning engine and rear end codes. I noticed there is a "C" engine code in the 1995 manual. It says this is a 5.9 engine. Did ford put a cummins in some of the pickups between 1991 and 1995?? I've seen a couple advertized in the past. Was this a turbo model? Anyone out there have one?
Well I know of a F350 (possible dually) 1993 with a C engine code. I havn't been able to find out what engine is in the truck yet as they were closed on Sat when I called.
I have never heard of any Ford with a factory Cummins but anything is possible and if it has one it will be turbo diesel, '89+ Dodges were all turbo diesels
Thanks for the input. I have a vague recollection that a cummins could be ordered on F350's, but I was thinking it was back in the mid-late '80's. But perhaps I am confusing that option on bigger ford trucks such as F700's.
Tony
Ok, I found a vin checker website. The "C" code is a 7.3 IDI turbo of the 1993/1994 version. The 7.3 IDI non-turbo is a vin K. So it appears that the axle code decoder chart is incorrect.
All fords I've seen have a "M" for idi diesel, "K" for idi turbo diesel and "F" for the powerstroke diesels. If I remember correctly the "C" was for a gasser.
Hi, thanks for the reply. The 'M" code is the older 1988 to 1993 7.3 'fuel injected' diesels. The are sometimes referred to as pre-injected. In 1993 and 1994, ford offered a Indirect inject diesel in both a natural aspirated version and a turbo version. I'm not sure of all the differences between Indirect Inject and pre-injected, but there was a difference. C code is not the gasser. the EFI 460 code is G and the 351 is H. I've recently got emails from 2 sellers of these Indirect inject 93/94 models, one selling a C and another selling a K indicating that the 'C' code is the factory turbocharged unit and the K code is the un-turbocharged IDI. Alot of 'K' code diesels seemed to end up with aftermarket turbo units on them so it's sometimes confusing when a fellow advertises "turbo diesel" and then has a 'K' code in the VIN #. F code is definatley the Direct Inject power stroke motor as you mentioned.
Tony
Here's what I think is accurate in terms of engine codes. Everyone is free to offer additions or objections.
Y 4.9
G 351 2bbl carb up to 1985
H 1984-'86 4bbl 351 and EFI 351
1 6.9 diesel fuel injected
M 7.3 diesel fuel injected 1988- 92 or 93
K 7.3 IDI 93/94
C 7.3 IDI Turbo 93/94
F 7.3 DI Powerstroke Turbo from '94 1/2 on.
L 460 carb 1987 and older
G 460 EFI 1988 and newer
The following came from my 1994 truck shop manual that covers econoline, F-150-F-350, bronco, F-super duty.Y 4.9 300 I-6
N 5.0 302 V-8
H 5.8 351 V-8
R 5.8 HP 351 V-8
C 5.9 359 I-6
G 7.5 460 V-8
M 7.3 445 V-8
F 7.3 DI Turbo 445 V-8
K 7.3 IDI Turbo 445 V-8
Nowhere in my manual does it mention the 5.9 other than this chart.
I was wondering about that myself. Why does ford insist on calling it a 445 even though International, the manufacturer, says it's a 444. Maybe it is one of Fords selling points, trying to make the engine sound bigger. Who knows.
N 5.0 302 V-8
H 5.8 351 V-8
R 5.8 HP 351 V-8
C 5.9 359 I-6
G 7.5 460 V-8
M 7.3 445 V-8
Well that's what the axle code chart that this website uses for information also. It's very interesting that your manual also includes the I-6 after the 5.9. Maybe they had in mind to put the cummins in the pickup ?? lol If you use http://www.autocheck.com/autocheck/1...209=0&_414=706 and plug in the vin #2FTJW36C7PCB24503 which is a real truck for sale in autotrader it will show that it is a 7.3 IDI. It doesn't say if it is a turbo or not, but I emailed the seller and asked him if it was a factory turbo or aftermarket. He stated it was factory, (but could be wrong). I then emailed a guy selling a 'K" code turbo diesel on ebay asking him if it was factory or aftermarket. He said it was aftermarket but it was the exact same as factory and was a garrett turbo. I guess my sampling of 2 examples doesn't give the best base of information, but that's how I came up with the info so far. Thanks for the input . We'll get to the bottom of this yet.
Tony G
I dont know if any one here can confirm this,but i am sure i heard or read somewhere the the diesel trucks sent to Austraila(sp) were fitted with the cummins 5.9.There must be someone that reads this forum from down under??
