Oil Coming From FlexPlate Bolts on 302?
Is it normal to get oil out of the bolt holes when you remove the flexplate to change it? When we removed the bolts as we loosened them to change a bad flexplate we started getting crankcase oil draining from the bolt holes. Is this normal on the early 302's? Thanks for any info you can give to us.
Sam
Sam
The crankshaft is bored all the way throught - so some oil does sit up in there as it is sloshed around inside the motor. When you replace a flywheel/flexplate on a 302, you should always use loctite or a sealant on the flywheel/flexplate bolts to prevent a slow steady leak. Some leakage upon removal of the bolts would be normal.
doesnt sound right. could be more like your rear main seal is going to me. id have to look at my 302 that came out of my bronco but i dont remember any oil on them. could be wrong though
I just changed my motor and the previous post is correct the bolt holes for the flexplate/flywheel are bored right through and the oil from the back of the rear main could seep out if one of the 6 bolts was removed and as a general practice locktite should be used on those bolts to prevent them from loosening and prevent any seepage but if the bolt was tight it would be minimal.
GreatNorthWoods
27
04-25-2011 12:53 PM
timbersteel
10-14-2010 04:08 PM
bigjohhanson
06-27-2001 09:27 PM
