Idle air control!!!
Old Jun 30, 2004 | 02:18 PM
86I6WontStart's Avatar
86I6WontStart
Idle air control!!!
hey guys,
Ok now we know that the truck starts, but here are the new problems:
where is the IAC?? also, I see 2 kinda of electric items hooked up to the vac lines one is from the canister to the carb w/ a bi metal plastic thing, the other one coming from the PCV valve joining to the first hose on a tee to canister???
when I start on cold the engine run good i give gas and it's fine till it gets hot and when I give gas it tries to stall. When it tries to stall I give enough gas to raise rpms and play w/ the idle mixture but I don't get ups or downs.
I always need to hold the choke open to start the engine if not it won't start.
Old Jun 30, 2004 | 02:41 PM
javi2001's Avatar
javi2001
What's your truck's configuration??? Carby? electric Carby? EFI?
Old Jun 30, 2004 | 06:11 PM
86I6WontStart
has a carburator, electric choke
Old Jul 1, 2004 | 01:54 PM
javi2001's Avatar
javi2001
Well, there is no IAC valve on your truck. It seems to me your carb is inyecting too much fuel, make service, then we'll know...
Old Oct 12, 2004 | 09:19 PM
86I6WontStart
Hey guys!!!!! OK. Now that the truck runs, finally on the highway, when I go at 55-60 mph sometimes it jumps. when I'm braking the idle is high and when i stop its still high, all of the sudden the idle will slow down then back high again. I'll say the RPMs are like 1500 when is high.
When I driving on a small street I can do 35 mph w/o pushing the pedal, then it'll go to normal then I need to push the pedal.
Everytime that I start the truck cold or hot it'll make a whistleing noise (annoying) then it'll stop.
It'll be times that when I take off I need to hit the clutch so I can gain power, because if I push the gas its like its gonna stall.
Sometimes i dont take hills cause it wont go if i dont help it w/ the clutch and on 2nd gear, when usually it'll take 3 rd gear only.
Sometimes when I'm turning into my neighborhood the idle is slow as soon I turn to my driveway it'll go up like 1500rpms and stays like that.
My truck is using way too much gas in 2 days I put 30 dollars.
Theres no emissions here, should I just cancel all the vac lines???? and the EGR valve also???
Reminder: my is a 86 F-150 I6 300 4 speeds 119,500 miles
Old Oct 14, 2004 | 04:41 PM
javi2001's Avatar
javi2001
Well, after fallowing your lines, I found 2 things:
1º There is an air leak, try to find when the whistleing noise is pressent.
2º Your truck still going over fuelled, that's the reason it can run with an air leak and also High Idle.
Old Oct 14, 2004 | 06:40 PM
paulfix's Avatar
paulfix
On my old truck the throttle plate shaft had worn and the throttles would stay stuck open just of idle
As far a your milage you need to figure your miles per gallon not dollars per day
