Hard tonneau cover (tilt type) for '68?
Here is a tid bit of info that someone might want to know......if you are looking for a tonneau cover(either type).
The tarp that I put on my '67 LB is the same as the mid 90's LB. I saw the ads for our year tarps and the price is OUT of this world!! I went to local shop and he got the size sheet out and compare my bed to the chart. The mid 90's version was a perfect fit. I ordered it and installed it. A perfect fit!
DON'T be fooled into thinking that you have to buy the HIGH priced model that is "made" for our years. The beds did not change that much(until the SD version) where they taper front to back.
As for a "hard" top. That might be a bit harder to fit, since the design of top may have to line up with side of bed. The radius at the top may interfere or not close tight.
Now, if you want a soft top that lifts, I'm sure you could get one like I did.
Good Luck
Larry
Good Luck
Larry
