1995 F150 4X4 5.0 performance - Ford Truck Enthusiasts Forums
Old 06-24-2004, 05:10 PM
slimslick slimslick is offline
slimslick is starting off with a positive reputation.
Question 1995 F150 4X4 5.0 performance
Hi, I'm also a new member. What I have is a 1995 F150LXT 4X4 5.0 Auto/Overdrive. I've added a single to dual exhaust system/K&N induction filter/Hyperchip and I plan to add headers. What my question is what kind of performance improvements can I make with a non programmable computer and make improvement without upsetting the programming.
Old 06-24-2004, 08:07 PM
f100guy f100guy is offline
f100guy is starting off with a positive reputation.
you can make your own ram air, there was a thread on this site a few months back that somebody made themselves. you could also get 24# injectors but then you need to reprogram the MAF sensor or get an aftermarket one. port the upper intake also.
Old 06-24-2004, 08:17 PM
94F150-408 94F150-408 is offline
94F150-408 is starting off with a positive reputation.
A fairly easy upgrade would be to elimanate your factory fan/clutch setup and replace it with an electric cooling fan. This will free up around 12-15 rear wheel HP.
Welcome to FTE!!
Old 07-07-2004, 06:19 PM
This what I gather from my fellow ford fans, Is
1. 73MM mass air flow sensor ($199.95)
2.#24 fuel injectors ($229.95)
3. Replace the factory fan with a electric fan. (?)
4. Y headers ($299.99)
5.Performer Mainifold ($529.00)
Old 07-07-2004, 06:28 PM
you have to get the new MAF sensor or have your stock one reprogrammed if you put bigger injectors in. so remember you would have to buy those together
Old 07-08-2004, 12:02 PM
95 F150 95 F150 is offline
95 F150 is starting off with a positive reputation.
I've got dual electric fans with independent turn on temperature controllers and they are great. I would recommend them to anyone who wants to free up a bit of power, have colder A/C and a more quiet running engine. They make a difference you can feel. I like the header idea too, I'm running Ford Racing shorties on my truck and they help out alot if you've had exhaust work done.
Fans and headers will make a noticable difference in power and can be done reasonably if you buy the fans from a salvage yard and get the Hayden controllers from Autozone. Just don't skimp on headers or the gaskets, you get what you pay for most of the time. I used some cheap gaskets the first time and they blew out within a few months so I had to pull the headers off and replace the gaskets
Old 07-13-2004, 01:18 PM
You Guys!! have given me some great Ideas. Thanks
5.8 swap red915.0lx User Gallery & Picture Display 2 01-23-2016 04:45 PM
Front Bearing??? fonefiddy 1987 - 1996 F150 & Larger F-Series Trucks 3 08-25-2015 12:05 AM
1995 LIFT bubbareitz 1987 - 1996 F150 & Larger F-Series Trucks 9 02-23-2015 12:33 PM
Gear ratio upgrade jimmy wade 1987 - 1996 F150 & Larger F-Series Trucks 10 07-31-2014 05:03 PM
Trans swap 4r70w for E4OD joshuahaney 1987 - 1996 F150 & Larger F-Series Trucks 2 12-09-2012 10:22 AM
Tags
150, 1995, 4x4, 50, 95, engine, f150, ford, fuel, improvement, improvements, injectors, mods, performance, proformance
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
