1978 - 1996 Big Bronco
Pulling codes.
Old Jun 22, 2004 | 07:11 PM
AYoungblood's Avatar
AYoungblood
Pulling codes.
I just did a bunch of mods to my truck and I pulled these codes:
KOEO- (Where there is a " " means it was a pause)
11 11 - Means "system passes"
KOER-
4 1 42 77 52 42
4 - i think is the engine code
1 - no idea
42 - System Indicates Rich
77 - Operator Error Dynamic Response Test
52 - Power Steering Pressure Switch Circuit Did Not Change (I didnt turn the wheel)
Has anyone had any experiance with these codes?
Any idea how to fix 42?
Also what is 77?
Thanks guys,
Adam
Old Jun 23, 2004 | 07:37 PM
Wakeboarder141's Avatar
Wakeboarder141
Make sure you depress and release the brake, along with the overdrive cancel switch if equipped before the codes start.
