dual gas tank problem
does you gas gauge just read empty or does it rise past the full mark and stay there? the reason i ask is because i can't figure out if my gas gague is not working or if it is just out of sink. when i turn the truck on the gague goes past the full mark and stays there. Does this mean the gague is still working?
ive got a problem kinda like that, but when either of my tanks is above 1/2 of a tank, it will stick on full,if either goes below 1/2 of a tank, the guage will jiggle back and forth between full and 1/4, when it goes below 1/4, it will stick on empty, then you start lookin for a go juice station
The pumps you can get just about anywhere. The sending units are a little more harder to find especially for the year differences. I bought one from www.rockauto.com for $75 and the other on ebay for $45. For this price neither came with pumps. Complete they run between $125 - 150 dollars. The pumps are about $30 each and the same for both tanks. The front are rear tank sending units are different.
I got a good deal from a friend who owns a auto shop. $150 for a new front gas tank and sending unit without the pump. I was wondering if i might have installed the sending unit improperly because the fuel gague doesnt work right. the rear tank gague works but when i switch to the front it drops past full. if i turn the truck off on the front tank the gague drops back to 3/4 full and when i turn it on it rises past the full mark like it wants to go farther.
i guess i am just going to have to live with it and pray that my leaky rear tank holds enough gas to get me home when the front runs dry.
