Sponsored by: Real Truck
ATF everywhere.........
Old Jun 17, 2004 | 07:36 PM
clayduster71's Avatar
clayduster71
Question ATF everywhere.........
I just pulled in from a 300 mile trip and automatic transmission fluid just started pouring out between the transmission and the motor. Its coming out the hole in the cover below the torque converter.
Maybe a pump seal?
( I knew I should have bought that stick shift I was looking at......)
Old Jun 17, 2004 | 09:21 PM
Yeti's Avatar
Yeti
That sux for sure.. Sounds like a seal some where.
Warranty I hope?
Old Jun 18, 2004 | 01:23 PM
clayduster71
Torque converter, bushing and seal kit are being installed. Putting in a larger torque converter this time to help with the towing. The last one self destucted.
This is the 3rd F-250 for me. Two of them have screwed up the torque converter.
I think the Power Stroke is an awesome engine. The rest of the drive train leaves a lot to be desired.
Old Jun 18, 2004 | 02:00 PM
jetjock16's Avatar
jetjock16
Ford makes the best drivetrain in the buisness..... maybe you should of made your second two 250s... 350s??..... try towing with and HD(chev) sometime if ford doesnt cut it for you.....
Old Jun 18, 2004 | 02:01 PM
cwb's Avatar
cwb
Don't get me wrong, I feel for you but try finding another truck with axles like Ford's and then try breaking them.
Old Jun 18, 2004 | 02:36 PM
iskybantilus's Avatar
iskybantilus
maybe its time for a 6 speed if you do that much towing?
Old Jun 19, 2004 | 07:10 AM
clayduster71
FYI,
The first two were 350's......didn't tow with the first two either. I agree, it is time for a 6 speed.
