Code 46???
Old Jun 16, 2004 | 08:37 PM
cookch1's Avatar
cookch1
Code 46???
Hey guys, I've got a 1987 F-150, I6, fuel injected. It runs rough so I pulled some codes and found engine running codes 46 and 25. My Haynes manual tells me that the 25 is the Knock Sensor not responding or responding too little but I can't find what 46 is. Any help??? This is the first time the truck has actually stayed running all the way til the WOT test.
Old Jun 16, 2004 | 08:52 PM
bobcf's Avatar
bobcf
thermactor air system unable to bypass air (vevt to atmosphere). or, distributorless ignition system (Dis) or distributorless ignition system (EDIS) problems-primary circuit failure in coil 2.
sunpro ford code scanner
Old Jun 17, 2004 | 05:16 AM
cookch1's Avatar
cookch1
Thanks for the reply! I will troubleshoot the thermactor system and I guess test the coil? Could ignition timing being off give the distributor codes? It sounds like the knock sensor and the thermactor are more closely related.
