Please help '98 2.5L - P0340 Camshaft Position Sensor
I have a camshaft position sensor circuit malfunction error on my '98 2.5L Ranger. I have swapped the sensor, and also used my ohm meter to insure the wiring from the powertrain control module to the sensor is good. But I can't seem to get it fixed. I have actually swapped in two new sensors, so I suspect that a bad sensor is not the problem. Could it be that the powertrain control module is bad and reporting this error? Any suggestions would be appreciated.
I would send an email but I get this message:
"Email privileges are not enabled for your account. You must be a member of this site for at least 15 days and have at least 15 posts before you can use the email form to contact other members. This is due to abuse of the system by spammers and scammers."
Apparently I haven't known about the forum long enough to get full use of it.
I ended up getting a rebuilt PCM to get rid of the P0340 (camshaft jposition circuit malfunction). Truck is still not drivable. Starts out with a rough idle which smooths out, hitting the gas causes the engine to rev briefly and then cutback as though you released the gas pedal. Now reading P0171 SYSTEM TOO LEAN (BANK 1) as DTC error. Anyone with troubleshooting tips for this DTC?
Running lean. Usually means a vacuum leak (vacuum lines/hoses, PCV valve, intake gaskets, bad EGR, etc.) or fuel a delivery problem (low fuel pressure, clogged fuel filter or injector(s), bad pump, etc.).
Look up the code here: http://rockledge.home.comcast.net/Ra...llery/DTCs.pdf
Originally Posted by rwhitson
P0171 DTCs.pdf is blank under possible causes. I'll look for the things your list. -RW
Possible causes of a DTC P0171:
Fuel system
clogged fuel injector(s).
Low fuel pressure.
Contaminated fuel injector(s)
Ignition system
Spark plugs.
Spark plug wires.
Coils
Induction system
Air leaks after the MAF sensor assembly.
Vacuum leaks.
Restricted air inlet
PCV system.
Improperly seated engine oil dipstick.
Base engine
Oil overfill.
Cam timing.
Cylinder compression.
Exhaust leaks before or near the HO2S(s).
Tips:
Check intake air system for leaks, obstructions and damage.
Check air cleaner element, air cleaner housing for blockage.
Verify fuel level.
Verify integrity of the PCV system.
Check for disconnected spark plug wires.
Check for vacuum leaks.
Verify customer did not run out of fuel.
