Sponsored by: Kumho
Dead Drag Link?
Old Jun 13, 2004 | 01:09 PM
GeneStoner's Avatar
GeneStoner
Dead Drag Link?
How do you know when your drag link (and asst. components) have given up the ghost?
Old Jun 14, 2004 | 08:06 AM
78fordman's Avatar
78fordman
well, just have someone get inside the cab and turn the wheel and see if there is play at each tie rod. If you do replace your steering components, replace them with moog stuff. I replaced all of my steering arms and the moog tie rods are about 1.5 times larger than the stock ones. Now if you have loose steering, you can also adjust the steering box for a tighter adjustment. Just park the truck on level ground and point the wheels straight. Loosen the jam nut on the steering box, it will be on top with a bolt sticking out, and tighten the bolt until tight, then loosen 1/4 turn and tighten the jam nut. Hope this helps.
Old Jun 15, 2004 | 12:20 AM
GeneStoner's Avatar
GeneStoner
Is that the way the Ford manuals say to adjust the box?
Man that sounds too easy...
Old Dec 3, 2004 | 12:44 AM
GeneStoner's Avatar
GeneStoner
Really????????
