Ohio Chapter Join Chapter, Leader: RUNVS
Ohio Tubing Bender/Exhaust man?
Old 07-12-2004, 09:00 PM
ske's Avatar
ske
ske is offline
Question Ohio Tubing Bender/Exhaust man?
Color=Blue
Greetings Ohio Chapter,
I hope someone around central Ohio on this list is a tubing bender/ exhaust man/woman? I have a 91 F-250 w/ 460 that needs a cobbled up cat replacment tube removed. I would like to go from manifolds into two hi flow cats then into one 3" pipe out in front of the right rear wheel. Muffler shops won't touch it because of the previous owner putting the cat replacment tube in it.
I'll gladly drive a reasonable distance to get this done!
Thanks guys,
SKe
Old 07-12-2004, 09:47 PM
F2504x4's Avatar
F2504x4
F2504x4 is offline
Hi and welcome to O.C..
i had friend in the same situation. what he did was removed the complete exhaust, put it on a trailor to the muffer shop ...no fuss. they are not allowed to remove cats or bypass tubes but can install legal replacements.. hope this helps...try calling the shops about doing this..
