Attention All 57 - 60 F-series Owners for the Registry
#91
Hi Guys....
I am off to pick up another 60. Its pretty much a gonner as there is no straight metal on it but it does have the Shortbed frame and 9" rear end under it so Im going to save at least that much, The grill and interior are gone as well as the front glass all fenders are dented pretty bad, grill is gone, the hood has a few small dings and holes(3/16")X2 from hood ornament? bed sides are good as well as the front panel cab has rust and dents...
and is it ugly...but for free Hey what the heck
Shane.....IT HAS A GLOVEBOX DOOR FOR #'s.....So I will get them to you before I bury it
also has a 302 and C4 radiator support looks good, has the stock steering box and wheel(black with missing button from center)
I plan to pull the doors, stab the side with the forklift and flip it on its side. then proceed to torch the sheet metal loose to get the rolling chassis loose, then use siad forklift to place all body parts removed into dump truck and hual to scrap metal yard
I will save hood, doors, radiator support, heater box, stock radio, steering box...does anyone need any of the listed items??
Glack
"another one of them thar fridge trucks in the collection"
Glack
#93
OK I have this beauty of a truck in is final place to be a truck, it will be torn down in the morning
Data plate info:
F10J0D23614
110 V F10J 0214 A 01
09800 126 4000
9800 pounds GVW??? whats with that?? on a stepside bed??
Doors look a little better than I thought
looks to have 3-4 colors on it over the years too looks to have been the Teal color then a green then a dark blue now baby blue. the place I picked it up from decided to add a few items to the pot...6 bald tires, 3 bench seats, a few cinder blocks and a couple of rotted 2X4's...Whoops...did you see that??? it all just fell out while we loaded it on the trailer
Glack
Data plate info:
F10J0D23614
09800 126 4000
Glack
#94
Glack - now what the heck can I do with a Date code of "0214"??!?
Is that 02K? Y2K? K-Y?
It was Academy Blue, as a youngster. What do you want for the steering box? Email me people don't go bananas. And send me a picture of your new POS truck!
Shane
Currently living in Columbus and
Cincinnati simultaneously
Shane
#95
Shane...Sorry was supposed to be 02H...wrote it down in a hurry and didnt see it properly...I had a hay day with the torch, cutting the cab loose and the front sheetmetal off. I pulled the rear glass and doors. steering box was cut loose(just cut the bolts) and will have it out in the morning and have the cab off...This is great, cutting it all off knowing I dont have to use it again. The frame looks straight so far and all mounts look good. the steering box seems to have play in it, I dont know if its loose(out of adjustment) or has broken worm gear...probably just loose. the 302 seems to be a vintage 289..to bad its not a hi po or boss.
Glack
Glack
#98
#99
'57 - '60 F-Series Registry
Thanks for the registry!!
My '59 Stepside (292/Auto) doesn't have door jamb or glove box info....but it has a plate on the firewall...I'll send photos of brass plate and truck soon
Gayland Crutchfield - Atlanta.
Plate info:
U.S
U.S. Marine Corps
Truck, Cargo, Pick-up 1/2 Ton 4x2
Model: F-100
Capacity: 981
Serial No.: F10C9A-17474 (which is the vin)
Year of Mfr.: 1959
Engine Model Nos.: EEH
FSN: 2320-542-2527
Contract No.: DA-20-113-ORD-24419
Shipping Wt.: 3540
Gross Wt.:4800
Overall Height: 74.0
Width: 76.3
Length: 192.9
MFD BY Ford Division of Ford Motor Co.
Plate info:
U.S
U.S. Marine Corps
Model: F-100
Capacity: 981
Year of Mfr.: 1959
FSN: 2320-542-2527
Shipping Wt.: 3540
Gross Wt.:4800
Width: 76.3
Length: 192.9
#101
59 panel tuck
Check out my website www.cmcsigndesigns for a picture of my 59 panel truck. It was a 4 year project and is currently having the automatic transmission fixed and I hope to be back on the road with it soon. I am finishing up my 69 mach I restoration and have just started a 55 pickup project. I have been away from the forums for a while but enjoy how they are loaded up with very useful info.
#103
I had to buy a pickup to put an original frame back under it. It was sitting on a 79 ltd frame that was a foot too long. After I got it swapped, I put in a Mustang 2 front with discs and used the ol 79 rear end after I cleaned up the coil spring mounts. It has a 68 302 4 brl and an automatic, before the trans went out it was running great on the highway 60-65 no problem. I hope to have the trans back in in a couple of weeks. It is a great advertisement for my business!
#104
'59 F100
I currently have a 1959 F100 and a 1960 F100. The 1959 is the one tha I am working on. The data plated info is:
F10J9K21026
WB 110
Color R
F10J
Date 12M
Trans A
Axle 01
I have installed a 429 ci (carburetor)/C-6 combo, a rear-end flip kit, the front suspension from a 1976 F100 (twin-I beam w/disc setup) and dropped front axles.
I didn't cut the frame for the suspension install; rather I removed the front cross-member and straight axle. Then I installed the cross-member, frame-towers, etc. from the donor (frame width is the same).
Since the '59 frame is straight (not arched over the axles like the 1976), the result was a bit of a front-end lift. By installing the dropped front axles, I got a mild lowering effect (fenders are about 1 1/2 inches above the tires.
To get the same effect on the rear I installed the flip kit and reversed the rear spring hangers. The truck sets level and has an over-all drop of about 4 inches. I'm not quite ready to put it on the road, but will be before this Fall.
I am in the process of finding a new home for the 1960 F100.
OldFords
bad attitudes
F10J9K21026
WB 110
Color R
F10J
Date 12M
Trans A
Axle 01
OldFords
bad attitudes
