View Poll Results: Do you notice any difference with or without overdrive?
I also get better city mileage out of overdrive
27.78%
I get the same city mileage either way.
27.78%
My city mileage decreases out of overdrive.
44.44%
Voters: 18. You may not vote on this poll
Better city fuel effiency out of overdrive?
I do mostly city driving. I have a lariat with the onboard computer which displays fuel economy. I do not have very much faith in it's accuracy. I have been playing around with overdrive, and without. I drive the same route everyday from work and there are not much for traffic variables because I drive at night when there is little traffic. The computer shows 12.80 (+/-) mpg while driving the same route daily while in overdrive. I noticed that my freeway mileage gets better at higher rpm say 65-70 mph vs 55-60. I have noticed that turning off the overdrive in the city increases my mileage to 14.70. Like I said, I don't know if the computer is very accurate, but it does recognize a improvement.
Originally Posted by WhiteNight
You'd think that if this is true that Ford would advise of it.
Having overdrive on will give you the best mileage, at least from my experience, unless of course the truck is hunting between gears. In my truck it kicks into overdrive at around 40-45 so as long as you're running steady at that speed you should get the best mileage. I only turn overdrive off in the city if the traffic is stop-and-go or if i'm going under 40 for a long time. I also heard on a car show that Chevy trucks supposedly get their best mileage at between 40 and 45 mph, which is most likely the minimum speed those trucks can be in overdrive. So ford's shouldn't be much different.
Originally Posted by rljphx
It seems nearly impossible to get better milage without overdrive than with. Simply a basic gearing issue.
IMO it stands to reason that higher rpm in the city may be a bit more efficient too.
I cant provide a full report yet, but when I am satisfied with results from further
goofing around I will post my findings.
I think Toreador is doing the same.
The answer is kind of obvious. At 40 mph, you run slightly less rpm than at 60 mph. So your fuel/time ratio would be larger. However, at 60 mph your distance/time is greater than at 40 mph. So if you divide (distance/time) by the (fuel/time) you get distance/fuel which is mpg. The best mpg occurs when those two values produce the largest mpg value.
