What is good gasket date ??
Doesn't look like bolts have been removed, but my engine build date is 12/11/1997. The TSB and ONP only apply to engines built before 5/31/97, so it appears that my engine is good to go !!
Anyone have any other info on the date when the good gaskets started going in ??
Thanks Blue, but that is where I got the TSB and ONP dates in the first place. I read on this forum that the gasket problem applied to '97's and some '98's. Since the cutoff date on leakingfords indicated engines built no later than 5/31/97, I did not expect that '98's were being built yet, so I was just checking the forum to see if anyone else had other info. I don't want to spend all the $$ paying a dealer to fix the gaskets if I am safe, nor do Iwant to burn a weekend doing it myself unless I have to.
I have a 1999 4.2 an just hit 70k. I'm not sure on the engine build date, so I figure I'll just replace the gaskets before problems arise. At $12 per gasket, it just seems to be worthwhile to have the truck out of commision for a week to fix this instead of gambling and then needing to drop $5k on a new powerplant
Saw tat sentence Sigma, but other places in the same website suggest an earlier date. If leakingfords is the authority for that date, then I am looking for some corroboration for either the May 31 1997 date or the January 31 1998 date. The Ford info suggests the earlier of the dates, but leakingfords.com says otherwise.
vatreefarmer
10-28-2013 12:04 PM
