Adding Propane??
Adding Propane??
Hey guys: I wanted to ask before I do it. I have a 2000 PSD (see gallery for all mods) and I tow alot, the truck runs pretty good but I would like to have a little more hp. If I add propane to her what kind of kit should I get and will I see a noticable difference in towing performance? And is there anything else I need to do to the truck before I add it? Thanks for any and all help. JL
If you understand how these systems work, it would be cheaper to make your own. If you don't, (and I didn't at the time,) I'd recommend the Powershot2000 system. (I see that you've got a BullyDog chip, and that company also makes a propane system, but I think it's got it's weaknesses when compared to a Powershot2000.) The Powershot is simple, relatively foolproof, and will give you a definite boost in power, approximately 80-100rwhp.
With your list of mods, you've got all the stuff you need to maximize the system, but you'd probably need to get the chip reprogrammed for propane use. With propane, you don't want/need any fuel timing advance, and your chip most likely has that, as a means to boost your current power.
Since BullyDog sells a propane system of their own, I'm certain they can reprogram it for you with a more suitable program.
I'm not very familiar with what the programmers options are. If it allows you to add fuel without advancing the fuel timing, then they'd work together. Assuming so, altering the fuel timing on the programmer would reduce the power output slightly from where it would be if advanced, but the propane adds so much more power than the programmer, you'd be thinking of the programmer as an accessory to the propane anyway.
On my truck, I had my flip chip reprogrammed to allow for propane. The program in my chip now isn't as strong as the program was before, when the fuel timing was advanced. However, now I flip on the propane, and have way more power than previously. My chip gives me the TDE0 code that I prefer, with all the tranny characteristics I like, and the propane supplies the power.
Using my butt-dyno, I'd say the propane adds three times the additional power of a chip.
