OD help.......please
Old May 31, 2004 | 07:22 AM
gottaGTO2's Avatar
gottaGTO2
I noticed this morning on the way to work that my overdrive has stopped working. I'm turning 2600 RPM when I used to turn 1900 RPM at the same speed. I've tried to push the OD on/off button, but the light doesn't come on. Hopefully this is an electronic problem. Any ideas??? Your advise will be greatly appreciated.
jeff
Old May 31, 2004 | 09:26 AM
01stroker's Avatar
01stroker
Jeff, you may want to check your fuses. I had a 93 gasser with the E4OD and it blew a fuse and if I rember correctly I had to pull it down into 3rd to get it to even move. Someone with more knowledge will come in.
Steve
