How many miles on your 351W?
Originally Posted by spdjunke
My 91 Bronco has about 190K miles on the original tranny and motor and treats me very well. Had to replace a few little things of course ( battery, alternator, etc ), but this has been a great truck, its still runs strong, gets about 11 MPG average and has never left me stranded.....
I have a 1993 F-150 with a rebuilt 351 5.8L V8 EFI at 130,000 miles, and i am already having problems. When ever I start driving, and it starts to warm up the engine starts to miss out. Causing jerking. I went through and replace the plugs, wires, rotor, and distrubutor cap, but the problem is still there. Any help?
Josh
66 F100.. 400 miles on a new 351w build. Not impressive, but it started as a worn out 89 block. I was hoping to just freshen it up, but found out it was a reman engine that was already bored .040 over and the mains were .040 under. It looked like they NEVER changed the oil.. ever! Interesting what they put in those reman engines... 2 different head castings and mixed rods from the 70's and 90's. Anyway, did a mild build starting from scratch... .060 over, picked up some E7 heads.. mild port job with Comp 252H cam. Not a hot rod, but runs great so far.
Have about 110 thousand on my 1990 with efi and an e4od. Runs good, but tbh i've hade to change some ancilleries, headers vibrated of, gaskets, and the timing gears ware shot wich i think is a bit wierd for that milage.
I used to have loads of old bmw's from about the same era that i built to drive to work as well as hillclimb and autocross events, and usually they made it at least twise as far before you ever had to think about opening the engine up.
Edit: Oh well, at least the parts are cheap for the windsor.
1994 F-150 4X4 with a 5.8W. 195,000 Kms. Running good but it's pretty tired as (I think) the first owner used it to tow a 5th wheel trailer and the 2nd owner (my dad) didn't do regular maintenance.
Compression test yesterday came up with Cyl 1 140, Cyl 2 130, Cyl 3 140, Cyl 4 140, Cyl 5 135, Cyl 6 145, Cyl 7 148, Cyl 8 125.
It uses a little bit of oil, about 1 litter between changes and it's down on power. A rebuild is in my future.
351W mileage
My 1969 351W has an estimated less than 200,000 miles, and is thoroughly worn out, burning and leaking rather a lot of oil.
I took it out of a beautiful Torino Hardtop many years ago. The Torino owner thought it was a good idea to let his 16 year old stepson borrow the car one Friday night, and surprisingly, he wrecked it!
I used the engine for years but these old carbureted engines just don't last like newer Fuel Injected ones do. Of course the oil is a lot better now too.
#30
Bought my 1997 F250 Heavy Duty about a year ago with 247,000 miles... it now has about 249K and change... I knew the original owner.. oil changed every 3K miles religiously!.. The 351W runs great and no smoke or oil burning... My wife is always asking me why I love tinkering and polishing such a turd of a truck... I tell her because it is MY turd truck and I love it!
