CD player in a 71 f-100?
I have a problem with my Pioneer Stereo. It is to wide for the crome peice that the radio is supposed to fit in. so tell me how you guys put a cd player in a 67-72 ford f-100. what did you have to cut or buy or what ever you had to do to make it fit in that chrome peice i really need some help with this thanx guys
Superman71
Superman71
Got a dremel? I cut the back out of my stock radio holder, but left enough of a lip for the stereo sleeve to hold on, then cut a line up each of the corners on the top and CAREFULLY bent the sides out. Bending the sides out to 90 degrees will make the width at the front and same as the back. A gap is made that I filled by clamping a peice of sheet steel or plastic or whatever(I think I used a smooth chunk of wood) to the inside top and filling from the back with some 4 min. JB weld. When the epoxy cured I popped the wood off and painted the inside black. It took a little filing and grinding witht he dremel to get every thing to fit just right, but it ended up looking really good and is difficult to tell its not stock since none of the crome trim was cut.
If you decide to try this, you can pick up an extra radio holder at a pull-a-part lot for about $3 in my area. good luck
superman71
25
02-28-2004 01:33 AM
superman71
01-12-2004 07:47 PM
superman71
11-26-2003 09:16 PM
superman71
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
07-24-2003 05:29 PM
