Jumps When STARTED
Old May 20, 2004 | 06:10 PM
ROFFL's Avatar
ROFFL
Question Jumps When STARTED
Have a 2002 EXPLORER XLS (18K). In the last two weeks, this happened three times. Truck was parked with gear shift lever in P. When I turned the ignition switch on, the truck jumped or bucked about an inch or two forward. Everything else is OK! Any ideas out there?
Old May 26, 2004 | 04:45 PM
ShouldaBoughtAToyota's Avatar
I had a slightly similar problem, my '03 would buck when you put it in gear after being parked for over 24 hours.
My dealer had to reprogram the computer and the problem went away, but it was a known Ford issue (I've since learned that until Ford puts it in writing, the problems are just apparently figments of the owner's imagination, at least according to my service dept)
Old May 26, 2004 | 06:13 PM
1956MarkII's Avatar
1956MarkII
My '02 Taurus does the same thing: start the car after it has sat overnight, and it rolls forward about 1 inch while still in park. Our service department says it's nothing to worry about.
Gf1028
Nov 16, 2016 11:21 PM
93nighthawk
Aerostar
Jun 15, 2016 05:31 PM
james Furry
May 19, 2016 07:34 AM
dioxippus
May 31, 2015 08:52 PM
FarmLaw
Aug 27, 2004 06:33 PM
