Leaking Fuel
Old May 19, 2004 | 10:06 PM
classicmetalman's Avatar
classicmetalman
Leaking Fuel
Hi all, got a problem and need some wisdom. Pulled into the driveway after work and noticed a leak under the bed of the truck. Turned out to be a hose to the gas tank , running parallel to the filler neck. Looks like a relatively easy fix, pull the hose and replace, but should i be concerned with gas spewing all over the place when I disconnect the hose, and what is this line anyway? Any advice would be appreciated, Thanks
Old May 19, 2004 | 11:15 PM
jsooke's Avatar
jsooke
As long as the fuel level is below the intake of the line you are okay. Basically, as long as you are not on a full tank and on level ground there wouldn"t be any fuel spillage.
Old May 20, 2004 | 12:13 AM
neverenough's Avatar
neverenough
It's the vent for the filler tube. Make sure you replace it with fuel line, not just any hose. As said above, make sure your tank is not full when making the repair. Best to be under half a tank.
Old May 21, 2004 | 11:28 PM
classicmetalman
Thanks for the tips
diesel 04 X
Dec 1, 2024 10:24 PM
Cyclonew
May 6, 2017 06:00 PM
Tobnpr
Aug 18, 2016 12:29 AM
blacklab1
Jul 7, 2016 07:39 AM
dbuck50
May 23, 2011 08:50 AM
