I am after a new F150 with a GVW of around 6800 need some input on the engine choices the standard V8 or the 5.4 is there a lot of difference in power or fuel mileage, I also will be looking to get the 3.55 ratio. any opinions
My Lariat has a 7200 lb GVW and a 5.4L Triton with a 3.73LS gear. Go for it! You won't be disappointed! I'm curious why you want the 3.55 rear end? My rig gets about 16.5 all-around MPG and has plenty of power. The difference between the 4.6 and the 5.4 is only about 1 MPG in my experience. I like the bigger motor for occasional towing. JMHO.....
the prevailing opinion seems to be that the difference in mpg between the 4.6 and the 5.4 is minor and if you want a rig for towing I would go with the 5.4
