Code 44?
Old May 12, 2004 | 11:30 AM
LAD's Avatar
LAD
Code 44?
86', 302 F 150. Remanufactured engline last yr. 15,000 on it. Also rebuilt tranny last year.
Had Hubby work on it ,cause of the stalling in Parking lot, and with Ac on and knew I'd lost pickup and power. We'd replaced alot of stuff. After spending all day , he found , no gasket on egr and some other stuff. Got rid of all the codes except one.-----44------ and he doesn't know or can't figure it out. My power is back, and the "revving is gone". But it still seems to want to stall a bit with Ac on. (egr and tps are new with engine). (had a 302 MM 84' for years so am fimiliar with some of the idosyncracies of these years). thanks.
Old May 12, 2004 | 11:47 AM
CLHAY's Avatar
CLHAY
Test your IAC (Idle Air Control) for soundness. Vacuum leaks?? Last resort (that I can think of), you might want to look at bumping the idle up just a tad.
Old May 12, 2004 | 06:22 PM
D Harry's Avatar
D Harry
I'm assuming it's code 44r.... running test. Had the same code on my 86 f150 302 EFI, also rebuilt with many new sensors. Can't figure it out. It means something about he smog pump not working correctly. I replaced the selinoids that control the pump... no difference. All I could figure out was the smog pump was shutting off when the engine was fully warmed up. I bypased the seliond that conrols the vacum to the smog pump so it(pump) is on all the time. Always blowing fresh air downstream of the Oxygen Sensor and keeping the Cats hot so they do their job. You cannot bump up the idle on these trucks. It now idles better. Had no vacum leaks. Was getting 18 vacum, not high but in range and very steady.
Old May 13, 2004 | 10:59 AM
CLHAY's Avatar
CLHAY
Oh sure you can bump the idle on these trucks.
Old May 17, 2004 | 07:16 PM
D Harry's Avatar
D Harry
How do YOU bump up the idle?
Old Nov 3, 2004 | 01:09 AM
punksnoted's Avatar
punksnoted
theres an idle adjustment screw on the very bottom of the throttle body.
Old Nov 8, 2004 | 05:33 AM
punksnoted's Avatar
punksnoted
thats how i do it.
Aungelique
23
Sep 28, 2023 11:00 PM
Roscoe316
Oct 21, 2016 07:51 PM
farmboy1227
Aug 16, 2015 10:25 AM
RedRebel
17
Apr 24, 2014 10:38 PM
Normspeed
1978 - 1996 Big Bronco
Jun 26, 2013 09:03 AM
