nos questions (TOM)
05-10-2004, 06:25 PM
on
nos questions (TOM)
got a few for u tom..........i know u started with a 35 and if i decide to get it i will too......but, with a 75 shot is there any timing or fuel increases necessary...and how long does a 10lb bottle last....and how expensive is a refill.......last but not least is there a system for efi fords with a 100 shot.....thx....
are high 14.s possible with traction????
05-11-2004, 12:31 PM
on
Tom is not here right now. But if you would like to leave your name and number and a bref message, he will get back to you as soon as possible.
Beeeeeeeeeeeeeeeeeeeeeeeeeeep
05-11-2004, 06:58 PM
on
strick, if you are wondering the our trucks can handle a 100 shot... yes it can. I think I remember Talley running a 125 shot on his truck to get a 13.8. He has lots of mods of course.
I think with a 75 shot, 14's are definately possible with the right traction.
05-11-2004, 08:08 PM
on
thanks true, did the diablo remove ur top speed limiter completly......im thinking about getting it in about 2 weeks.........might drive over and get u to help me put it in....?
05-12-2004, 03:27 PM
on
Yea, no problem. When you order it TELL KEN OVER THE PHONE to get the speed limiter removed. Mine got moved completely. I've been (on the digital speedo) right at about 120 mph on the way home from Houston one night, and I could have gone faster but I was satisfied. Yea, if you need help I can do it in about 20 minutes easily.
05-12-2004, 03:56 PM
on
Joe...and Talley also blew his motor up....or did you not hear about that? he spun two bearings, admittedly due to the use of NOS on it.
05-13-2004, 12:10 PM
on
how long of a drive is it from shreveport to ur house.......if ist only a hour or so i will just come on over..........what yall cookin??????
05-13-2004, 08:29 PM
on
incorrect Jimmy. He admitted it was because of IMPROPER use of nos. a 300 shot of NOS can be used easily, if you know how to make it safe for the engine.
Garrett
05-13-2004, 11:19 PM
on
wel but from the use of NOS :P regardless after too much use not rebuilding or strengthining your bottom end will screw your motor....
