97F150 Stuck in park - Ford Truck Enthusiasts Forums
Old 05-06-2004, 11:40 AM
emnrich
emnrich is offline
emnrich is starting off with a positive reputation.
My transmission won't come out of park. I can do the "trick" others have posted (cutting ignition half way on, put in N, crank, then put in gear), but have found that when I pull the fuse of the Park Lock or whatever it's called, I can put the truck in gear with no problem. Is there any trouble or damage that could be caused by not having the fuse installed? It also list a Control Timer in the owner's manual as using that fuse. Thanks.
Old 05-06-2004, 01:47 PM
1979ford's Avatar
1979ford
1979ford is offline
1979ford is starting off with a positive reputation.
Does your brake lights work? If the brake switch is bad it won't let the transmission come out of park. It's not sensing that your foot is on the brake.
Old 05-06-2004, 01:53 PM
emnrich
emnrich is offline
The brake lights are not working but they just stopped
yesterday. The transmission thing has been going on for about 6 months.
Old 05-06-2004, 02:55 PM
#1 ford tough
#1 ford tough is offline
#1 ford tough is starting off with a positive reputation.
You sure one of you wires isn't broke off your brake sencing switch. I have a 97 also and I found my wire was broke off so I had to splice on another wire and reconect it. It's a real pain having to crawl up under that dash.
Old 05-06-2004, 03:00 PM
emnrich
emnrich is offline
That is possible. Should I be checking out the switch connected to the brake pedal?
Old 05-06-2004, 04:39 PM
BlueOvalFitter's Avatar
BlueOvalFitter
BlueOvalFitter is offline
BlueOvalFitter is gaining momentum as a positive member of FTE.
Most likely,the wires going to the connector are broke.I had to resplice my wires and while I was down there I replaced the switch too.I did away with the plastic connection and used female spade connectors.And,it is very cramped under there too!
Old 05-07-2004, 06:39 AM
emnrich
emnrich is offline
I did the same thing. My taillights work and my truck will come out of park now. Thanks for the help. And yes, I have a stiff neck from craning it under the dash, even with the knee bolster removed.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
