Lightest Trucks
Old May 2, 2004 | 12:54 PM
rebocardo's Avatar
rebocardo
Assuming 2x4 F-100, I would try to ditch the front suspension for something custom fabbed out of 1/4 aluminum instead of that big steel I beam. I have seen people put Mustang II front ends under F-100s. Though I think that is too light duty for 2 tons of truck.
The newer windshields are literally pounds lighter and they break much easier then older windshields when impacted.
Old May 2, 2004 | 06:17 PM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
[QUOTE=
Click on chassis.
They say "$964 and up" for a truck kit.
You know, having a truck of our vintage done with a 60s/70s retro stock car design could be pretty sweet.
Happy Welding...[/QUOTE]
Thats a cool site ! These chassis are very cool they are all round tube witch
make them for NHRA Pro-stock truck ( Drag racing ) I wonder the price if you
pick it up already welded and 4 link bars 9in and strut front end .
P.S. truck kit is shipped to you as a pile of tubing and maybe 1 third of the
brackets you would need Although it would be fun to weld up .
Thanks for the link very cool!
Old May 3, 2004 | 01:40 PM
fordification's Avatar
fordification
Originally Posted by mlf72f250
Not cheap, but they have almost everything you'd need...
http://www.usbody.com/Pages_Trucks/67-Ford.htm
And here's your late-model truck tube-frame to go NASCAR racing...
http://www.childressracecars.com/truck_chassis.html
When I find a place that had U-weld-it kits, I'll forward that, too.
Yep, that 'usbody' is the one I was thinking of. Can you imagine all figerglass with the tube frame! There's a pro-stocker.
Old May 3, 2004 | 02:22 PM
mlf72f250's Avatar
mlf72f250
Glad to help out.
I don't have the $$$ to do a project like that.
But someone should really do that.
It's the kind of thing that *must* be done.
NHRA ProStock or 1970 NASCAR styling for great acceleration *plus* cornering..
Old May 3, 2004 | 02:47 PM
rebocardo's Avatar
rebocardo
Nice alloy wheels in the 15x8 size would shed about 10+ pounds per wheel (50 pounds for the total truck) over steel wheels. Plus, make the truck look nice.
I believe in full sized spares, though if you are not using your truck for towing or long distance travel, a mini-spare or even a smaller P235 sized tire would work.
Two bucket seats from an Aerostar weigh much less then the 30 year old OEM bench seat.
Old May 3, 2004 | 04:06 PM
fordification
I went with the Autodrag lite centerlines.
No spare, and bucket seats from a Mustang. I like the idea of the racing seat.
Old Jul 27, 2004 | 10:04 AM
fordification
Originally Posted by hoxiii
-Replace the steel inner fenders with the plastic ones from a later model truck
-move the battery to the cab area, preferably under cab
-go with hood pins so you can gut the hole latch mechanism
-get rid of the front bumper and put on a plastic or aluminum splash pan
-if you're in a warm area the heater core and mechanism can go
-firewall/floorboard insulation: do you really want/need it?
-drop the bench seat and get some fiberglass buckets
-steel door inserts
-Glass. if you're serious get into lexan, but you can't replace the windshield with it and have it remain street legal
Those are BIG weight areas. Just start looking around, see what is there that you don't really need.
Remember: It's easier to find 100 places to shed one pound than one place to shed 100 lbs
Justin
Some good tips.
I like the hood pin idea and the plastic/alluminum splash shield. Does anybody know where I could find them, or the plastic inner fenders?
Another huge weight saver but very expensive replacement would be one of Caroll Shelby's series alluminum 427's, like Scouder's.
Old Jul 27, 2004 | 10:14 AM
fellro86's Avatar
fellro86
Hijack a frame stub from a rear drive Lincoln town car, Merc or LTD, or mid 70's Cougar or Tbird, if you want it to stay ford. Otherwise, you can do the stock car trick and get a stub form a 70 -81 Camaro /Firebird, they don't have the frame bends like the full size cars, straight from the front.
Old Jul 27, 2004 | 10:29 PM
maximumhorsepower's Avatar
maximumhorsepower
*************, where did you get the fiberglass fenders? On another note,to reduce weight, you could replace the steel bottom of your bed with plexiglass or aluminum
Old Jul 28, 2004 | 09:05 AM
fordification
I found a place up here in Edmonton that had them. But now I can't remember the name to see if they also have f/g hoods. I like usbody.com's GT-500 hood. But I think they only sell it complete with the frontend.
The bed would save weight but at this point the backend is so lite, I can't take anymore weight off for traction reasons.
Old Jul 28, 2004 | 09:14 AM
fordification
Found them.
Cross Canada
Magnolia Tom
Jan 14, 2014 11:15 AM
84Fordvan
Feb 8, 2012 12:40 PM
tkiner
Mar 15, 2010 11:11 AM
BlueOvalfan85
Mar 7, 2007 09:36 PM
