Drilling tapered holes
Greetings!
I have a 1" thick piece of steel with a 5/8" hole thru it. I need to make this a tapered hole that goes from 3/4" on the large end to 5/8" on the small end (to fit the tapered shaft of a tie rod end.) I'm pretty sure there's a drill bit of some type for making this type of hole, but I don't know what it's called or where to find one.
I'm assuming a machine shop would have a drill press that would do this in a second, but I'd like to do it myself.
Anyone have any idea what these bits are called and where to find them? Also, any tips on drilling this kind of hole?
Thanks in advance.
Kevin K.
Thanks in advance.
Kevin K.
If the powers that be don't get PO'd, here is a suggestion. Check the link for what you want. Tapered Reamer
Sweet! "Tapered Reamer" is what I'm looking for. Now I can search the web and stores for one.
Thanks for the link. That's EXACTLY the one I need. If I can't find a cheaper one somewhere, I'll probably get that one.
Mike W, I'm actually drilling the steering knuckle on my D44. I don't know if I could get it off the axle much less onto a lathe. Thanks though.
Kevin K.
Kevin K.
The PO of the truck did the lift with bigger coils in the front and blocks in the rear. He never put in a drop bracket for the track bar or a drop pitman arm. He didn't even drop the radius arms. So, yes, the steering system geometry is very close to the stock setup now.
See pix here.
Kevin K.
See pix here.
Kevin K.
RyanMiller
04-27-2005 07:39 AM
William
26
01-03-2003 09:58 AM
