Problems
Old Oct 15, 2002 | 10:07 AM
mooner's Avatar
mooner
Problems
I replaced the glow plugs and now the truck seems to cycle a little longer. I also cleaned out the injectors and changed all filters etc. Now when I start the truck it fires right up and then dies after about 5 sec. It will not start again unless I use some wd-40. Once it statrs it smokes constantly (white). Could it be the injector pump, my truck has 250K on it and I don't know if it is the stock pump as it had 200K when I bought it. Also I have a pump from a newer 7.3 and wonder if they changed over the years.
Thanks
Old Oct 15, 2002 | 03:53 PM
alanscott's Avatar
alanscott
Problems
Old Oct 16, 2002 | 03:05 PM
argve's Avatar
argve
Problems
Sounds like you are getting air in the fuel system. What year truck is this? I would not use WD40 or any other kind of starting fluid with the glow plugs hooked up as it can cause the glow plug tips to break off and fall in to the cyl.
Old Oct 17, 2002 | 09:08 AM
mooner's Avatar
mooner
Problems
It is a 1990 E350 with a 7.3L engine.
Old Oct 17, 2002 | 11:52 AM
argve's Avatar
argve
Problems
[updated:LAST EDITED ON 17-Oct-02 AT 12:56 PM (EST)]Then I would check the return caps on the injectors. Did you replace the o-rings on each injector when you had it apart? Another trick is to install a clear line on the return side of the filter housing, if you have bubbles then you have an air leak.
From my understanding the Injection pump for a IDI is the same except for the really early 6.9l's (85-86 years)? But everything else is the same, just where they set the fuel delivery screw, as in for a turbo or not. Now the supply pumps are the same for all the years.
Vanzal15
Jul 23, 2013 01:36 PM
dyoungen
Jun 11, 2012 08:51 AM
flbmcman
Oct 25, 2011 05:25 PM
axel 56
Jun 14, 2011 09:34 PM
mudkicker715
18
May 18, 2009 09:33 PM
