1978 - 1996 Big Bronco
89 Ford Bronco Help
Old Apr 19, 2004 | 06:22 PM
Krelek1000's Avatar
Krelek1000
89 Ford Bronco Help
Okay I recently bought an 89 Bronco XLT and have been working on it. It throws a couple of codes that I do not know of. 21 and 67. I know that the 21 leads to the Coolant Temp Sensor, which I replaced, but it is still reading it. Also the temp sensor has the correct voltage 4.71 running to it but I do not know if it is the Sensor or the wiring to the Temp Gauge.
Also the engine is running hesitantly a bit. I think it just needs routine maintenance. Can anyone verify what exactly the code 67 means and what I should do about it?
Thanks
Old Apr 19, 2004 | 07:09 PM
DW2455's Avatar
DW2455
you have two engine temp sensors, one works the temp gauge and the other is for the ECM, so you may want to make shure you replaced the right one DW
Old Apr 20, 2004 | 09:11 AM
Krelek1000's Avatar
Krelek1000
I replaced the one on the top of the motor near the Distributor. Where is the other one located?
Old Apr 20, 2004 | 09:42 AM
DW2455's Avatar
DW2455
the little one to the drivers side of the distributor screwed into the intake is the one for the gage, the other one for the ecm should be to the left of the distributor screwed into the riser tube right above the thermosat housing, it is the one that will cause falt codes.DW
Old Apr 20, 2004 | 10:09 AM
Krelek1000's Avatar
Krelek1000
Ok. I get it now. I will take a look when I have a chance. Now the one thing that is a problem though is that the Temp Gauge only will work partially.
Old Apr 20, 2004 | 11:14 AM
Capone's Avatar
Capone
You may need to clean the harness connector after cleaning it, dab a little dielectric grease on it and snap it back into place.
You may also want to get the cooling system flushed and burp it so no air pockets cause hot spots.
ALso check the timing, if out of spec, the air cleaner box should have a catalyst sticker on it telling you how to set the timing.
cheers
R
