E250 Drl
I just went through this on my 2004 E250. I looked up a wiring diagram on the Alldata computer at the library and figured out all I had to do was unplug the module. I did that yesterday and it seems to be fine. No more DRLs and headlights still work manually.
If you want to disable your DRLs, the module is located behind the shroud under the hood just to the left of the hood latch. Pop out the air inlet tube, remove the 4 plastic pins holding the shroud on. Lift up the shroud and you can get to the module to unplug it. Since I have done this, everything seems to be working fine.
Jeff
Jeff
NJPRINGLE
07-24-2014 02:37 AM
International444
02-26-2014 06:00 PM
randallpb
1999 to 2016 Super Duty
08-23-2010 10:40 PM
