Need Help with carbs
Old Apr 18, 2004 | 05:09 PM
lancer's Avatar
lancer
Exclamation Need Help with carbs
I recently purchased a 2X4 Factory ford aluminum intake. I was wondering if anyone has an idea of what Holley carbs will fit this. He said it is from the mid 60's. Part #'s would be a great. Thanks for any help!
Old Apr 18, 2004 | 05:19 PM
pops_91710's Avatar
pops_91710
Can we get a little more information than that? Is this a small v-8, or a huge 460? Kinda helps to know these things.
Old Apr 18, 2004 | 06:28 PM
lancer's Avatar
lancer
OOOOPS!! Sorry guys. It's for a289/302. Thanks in advance for your replies. It's a big help.
Old Apr 18, 2004 | 10:21 PM
pops_91710's Avatar
pops_91710
Well, the smallest 4 barrels Holley makes is 390 cfm in a 4360 style. They are for a 2X4 tunnel ram. You'll have to de-choke one carb and find your own linkage. It still sems a lot of CFM for small block. I don't see what value it is for a truck. They are for high rpm engines. Take a look here at it.
http://www.holley.com/HiOctn/ProdLin...SC/0-8007.html
Old Apr 18, 2004 | 10:39 PM
LxMan1's Avatar
LxMan1
Holleys probably won't fit unless you can run them sideways. I believe they were made to use Carter AFB's. I would use 2 500cfm Edelbrock carbs.
Old Apr 18, 2004 | 11:15 PM
pops_91710's Avatar
pops_91710
I agree.That woulda been my choice as I like the way Carters tune and the fuel is on the sides of the carb, but he did ask for Holley info. I was indeed going to mention those Edelbrocks since they are a revived AFB, but I forgot. (it's the gray hairs, ya' know)
Did the tunnel ram manifolds sideways mount the twin Holley's? I can't remember. I do remember seeing them mounted that way, but I forget on what.
Old Apr 19, 2004 | 05:53 AM
lancer's Avatar
lancer
Thanks alot for the help guys!! I think i'll go with the edelbrock carbs. I was looking at them on the Jegs website and they say there made for 2X4 setups. The holleys all look to big. The motor is going in an 87 cougar and for some reason i had to have a 2X4 setup. (Look cool!!) I ran my setup on my desktop dyno and the motor made over 300 ft lb of torque from 2000 to 6000 rpm peaking at about 350 ft lb. Pretty flat curve. Should work well on the street i hope. Thanks again Lance
Damifiknow
Jan 15, 2014 06:45 PM
joshdavis50
Jun 14, 2008 12:03 AM
ken's1971
Mar 25, 2005 04:40 AM
canadiangal
Apr 22, 2002 09:48 PM
wildjon300ci
Electrical Systems/Wiring
Jul 28, 2001 10:08 PM
