91 explorer flickering lights
Old Apr 17, 2004 | 12:05 AM
starweb's Avatar
starweb
Smile 91 explorer flickering lights
i noticed this evening that there is a flicker in my headlights and dashboard.
also, i noticed my ampmeter is bouncing in unison with the flickering.
Old Apr 17, 2004 | 08:51 AM
TomCarperNGiles's Avatar
TomCarperNGiles
Check battery posts for corrosion, clean and grease if needed. If this does not correct the problem check the grounds with special attention to the one on the block. Also make sure that your belt does not need replacing. (i.e. the tensioner is at it's limit)
My '91 gets like this, once I clean things up it's fine.
Best of luck to you.
TomCarperNGiles
