View Poll Results: Which Penetrating Oil Works Best?
WD-40
10.34%
Liquid Wrench
13
11.21%
PB Blaster
58
50.00%
Kroil/AeroKroil
21
18.10%
Other (please post and specify)
10.34%
Voters: 116. You may not vote on this poll
Penetrating Oil
Penetrating Oil
Hi folks,
The subject of Penetrating Oil gets discussed occasionally over at the Garage & Workshop Forum, but I am kind of curious as to what some of you lubeheads over here in the Oil & Lube Forum have to say about it.
I've been using PB Blaster for the past year or so and am sold on it. IMO, it works better than the two old horses I grew up with, WD-40 and Liquid Wrench, both as a penetrant and lubricant.
So here's a little poll, please feel free to comment or elaborate based on your own experience(s), and if I missed a brand you like, post it. Maybe some of you even mix up your own concoction.
PB Blaster. First penetrating oil I've ever used that actually worked freeing up bolts.
I almost didn't buy it when I saw that gimicky "test" on the can. Spray it in a styrofoam cup and it will melt the cup. So the h**l what? The test is complete BS, but the product does work.
I use WD-40 as a cleaner/water remover/mild lubricant at work and can't say anything else would work better for that application.
I've used liquid wrench and was not impressed. I've also used a couple others that didn't make the poll (don't recall names right now), and wasn't impressed with them either.
